There is another knockoff as well. This guy sells plans for his version. $350 Budget DIY CNC Plasma Cutter - Quick and Easy - YouTube
Maybe it will work without changing anything? See what they say.
Hey Ronthomp, how’d you get on converting your machine? I have exactly same machine, I’m struggling with the finer settings with little support so interested in converting too
I just saw this. A friend wanted the Chinese machine so I traded it off. Just today, I bought a second hand Crossfire with the Firecontrol box.
Hey Ron that’s great news, I’d love to hear how you get on with the new machine. I’m considering exchanging mine tbh. I’m going to upgrade my compressor next week to something bigger with higher cfm as I’m sure that’s my current small compressor with 90l receiving tank is producing much cfm
Hi, would you be so kind to show me where the arc+ and - connect to inside the Huawei hicut 80. I want to use my plasma cutter on this same table you have, mine doesn’t have the three pong connection on the front and I’m gonna wire one in, but I wanted to see where Huawei takes the signal from.
That Plasma cutter is not compatible because it’s High Frequency Start, not Blow Back Start.
Features:
80 Amp IGBT pilot arc plasma cutter;
Automatic dual frequency (50/60Hz);
**High frequency start** and contact start hand torch;
Suitable for Stainless Steel, Alloy Steel, Mild Steel, Copper, Brass and Aluminum, etc.
It might work with the FireStar system. What An7h0ny stated is the Huawei table, not Langmuir
