yesterday I did some cutting of the projects I’ve been live streaming for the last week.
From today
Live streamed a couple forum topics this morning.
I plan on streaming again this morning in about 20 minutes .
From today
Wow you are a cutting machine!!! Will you sell most of that?
Yes most of that will go to the gallery or on rotation for the weekend markets.
The nevermore crow is for my wife. But I told her it hangs in the gallery till she needs it ( it is a Halloween decoration ) and if it sells I’ll build hear another one.
that is about 1.5 sheets 48x96 14 ga
Lets get started Again 5:30 AM nov 14 2022
Lets use AI to make a design for Christmas sign then post it to FireShare.
3D Model and Fusion 360 Download
Twitch live stream
Link from FireShare
Remix of design in this link
3:45AM MST
forum topics and christmas fireshare projects.
Repairing a DXF that has areas that are not creating profiles that can be extruded.
4:30AM MST
Making/ “Remixing” Christmas Themed cut ready files for Fireshare,
made a door hanger wreath
3D viewable model and Fusion 360 Download.
xmas 2022 wreath with antlers Christmas forum example 18" in wide
https://www.langmuirsystems.com/fireshare/xmas-2022-wreath-with-antlers-christmas-forum-example-18-in-wide
FireShare File
Tin…thanks for the files and the video. My kid wants to build the sleigh for his school fundraiser. What is the best way to modify the file for different thickness of metal? I think we will be using 16gauge.
Thanks again - Jason
The best way would be to create a fusion model from scratch that had easy resizing in mind so the model would be driven by the thickness and overall size.
The easy way would be to scale it based on the metal thickness you want to use. but this will scale the overall size. 50% reduction moving from .125 to .0625 in overall size.
The middle ground way to get thickness and overall size you desire is modify the fusion file above manually.
What size sleigh were you thinking of?
3am mst live stream. creating a unique birthday present design with cityscapes and compass rose.
This was the drawing I was given.
part way through
Wow you never cease to impress. Would you be willing to sell maybe .001 percent of your talent?
The overall size now is fine, my guess is that if j just reduce bt 50%, some of the features will be difficult to cut well. I like these files wherethe pieces slip together like this but it always seems like i am trying some different gauge metal than it was designed for.
It definitely can be tough. Maybe I’ll do a stream where I take that exact sleigh change it from 1/8. To 1/16
Looks great T.
It seems like we should be able to pull in the dxf into fusion then add some dimensions to get the job done, maybe even using a variable, so that the design could be changed on the fly by just changing one variable…
My Youtube Channel is Now up and Running . If you want any of these Twitch video topics move over to YouTube please let me know.
Starting a stream at 3:00mst pm
Building a lever that will bolt on to my hub to hold the wheel spindle steady so I can remove that ball joint nut… The end of the lower control arm broke off and is still attached to ball joint.
ugly and not really the way to go about it but it is what i am doing.
Enjoy the Stream!
make sure you show us when you use it. I am curious as to what your doing with it.
After 5 solid hours of sleep time to get back at it.
Streaming at 3:45-4am mst
thinking of a few mods to yestarday’s project
will start a design for fireshare using the canvas feature in fusion 360 a 5:15am mst after a quick break.
Ill add this to FireShare
FIXED NC FILE PIERCE DELAY NOW .5 SECONDS
xmas santa boy.nc (75.6 KB)
Hey TW, I love the videos. I learn something every time I watch. But I can just barely hear your voice. I have no issues hearing any other videos. Maybe you need a headset mic…?
