Don’t forget you were going to do one on 2d settings
I haven’t, like I said I’m doing more research and coming up with a lot of “new” stuff.
But tonight I can run through a simple piece of quarter inch plate.
I have a a few sheets in my truck I have to unload still.
Simple Plate Model from the first part of the video
I talked about this topic issue at the one hour mark of the video
https://forum.langmuirsystems.com/t/fusion-360-cutting-offset
The Wasp model from the end of the video
I’ll continue the CAM for the wasp in the future.
Thank you for watching.
Continuing the CAM on the Wasp
6 AM MST
I have not cut this yet but I was thinking 1/4" aluminum would be a good choice.
Fusion 360 Model and Download
Langmuir System’s Forum Topic
Twitch Live Stream available for 7 days. If you want it after that make a request and I can post it to my Youtube Channel
YouTube Channel
https://www.langmuirsystems.com/fireshare/wasp-example-project-from-3axisco-remixed-to-work-better-with-plasma-twitch-stream-quarter-inch-aluminum#comment-2998
FireShare download
wasp dxf tin example.dxf (751.0 KB)
I am going to live stream finishing the cam for this
Edger Allen Poe Raven Themed Hanging for my wife
At around 6:45 AM MST ?
it is a mix of single line and fully shapes.
We will have to generate multiple toolpaths
had to alter the design come more but now ready to cut!
yesterday I did some cutting of the projects I’ve been live streaming for the last week.
From today
Live streamed a couple forum topics this morning.
I plan on streaming again this morning in about 20 minutes .
Wow you are a cutting machine!!! Will you sell most of that?
Yes most of that will go to the gallery or on rotation for the weekend markets.
The nevermore crow is for my wife. But I told her it hangs in the gallery till she needs it ( it is a Halloween decoration ) and if it sells I’ll build hear another one.
that is about 1.5 sheets 48x96 14 ga
Lets get started Again 5:30 AM nov 14 2022
Lets use AI to make a design for Christmas sign then post it to FireShare.
xmas 2022 arabesque pattern wise man and forest.dxf (559.7 KB)
3D Model and Fusion 360 Download
Twitch live stream
Link from FireShare
Remix of design in this link
3:45AM MST
forum topics and christmas fireshare projects.
Repairing a DXF that has areas that are not creating profiles that can be extruded.
4:30AM MST
Making/ “Remixing” Christmas Themed cut ready files for Fireshare,
made a door hanger wreath
3D viewable model and Fusion 360 Download.
xmas 2022 wreath with antlers Christmas forum example 18" in wide
https://www.langmuirsystems.com/fireshare/xmas-2022-wreath-with-antlers-christmas-forum-example-18-in-wide
FireShare File
xmas 2022 reindeer wreath forum example tin.dxf (633.5 KB)
Tin…thanks for the files and the video. My kid wants to build the sleigh for his school fundraiser. What is the best way to modify the file for different thickness of metal? I think we will be using 16gauge.
Thanks again - Jason
The best way would be to create a fusion model from scratch that had easy resizing in mind so the model would be driven by the thickness and overall size.
The easy way would be to scale it based on the metal thickness you want to use. but this will scale the overall size. 50% reduction moving from .125 to .0625 in overall size.
The middle ground way to get thickness and overall size you desire is modify the fusion file above manually.
What size sleigh were you thinking of?
3am mst live stream. creating a unique birthday present design with cityscapes and compass rose.
This was the drawing I was given.
part way through
Wow you never cease to impress. Would you be willing to sell maybe .001 percent of your talent?
The overall size now is fine, my guess is that if j just reduce bt 50%, some of the features will be difficult to cut well. I like these files wherethe pieces slip together like this but it always seems like i am trying some different gauge metal than it was designed for.
It definitely can be tough. Maybe I’ll do a stream where I take that exact sleigh change it from 1/8. To 1/16
Looks great T.
It seems like we should be able to pull in the dxf into fusion then add some dimensions to get the job done, maybe even using a variable, so that the design could be changed on the fly by just changing one variable…
