I was designing a shelf for my plasma cutter last night… well I designed it a couple months ago and decided to add some tabs for spot welds and change the material from 14 ga. to 16 ga. simply because I have a bunch of remnant 16 ga on hand. At some point while editing the shelf I lost the ability to create a flat pattern. I get an error that says there is an issue with one of the bodies. When changing sheet metal rules is it as simple as changing the rule and the program updates the bodies and bends ect. for the thinner material or did I cause a problem when I changed the rule from 14 ga. to 16? The only other thing I can think is adding the tabs created an issue somehow?
I am going to mess with it some more tonight and see if I can figure it out. Otherwise, I will try starting from scratch… It might be faster to do that anyway… it’s just bugging me I can’t figure it out.
Thanks I’m starting to be a little bit more comfortable doing them.
Sheet metal bodies can be finicky. I feel it’s best practice to retry your flat pattern after most changes. Because it’s easy to have some mystery element mess it up and it’s sometimes quite a bit of backtracking to fix it.
All these different elements could have been the trigger to fail the flat pattern. The real answer is it depends a lot on what’s going on with the geometry in the design. If Fusion feels that any change that was made now does not comply to the sheet metal rules it’ll fail the flat pattern.
I know you mean some of those kind of things haunt me. If you get to a point you want to share your f3d file I could take a look.
Edit: I may narrow the slots, single line perhaps? Update: no single line does not work . a minimum slot width of half your material thickness plus a whisker.
This covers creating templates for different 2D profiles in the cam section. It also touches on the generation button which regenerates all the tool paths that need to be updated for a specific setup.
You are Welcome and Thank you for the feed back. The volume is low. Still getting use to this software. I’ll jack it up for the next video.
Awesome that is what I am trying to accomplish. Also I keep learning a ton doing these walkthroughs and solving issues.
These twitch video are not polished but I can get a thought out quickly without having to screen shot and type a bunch. This format seems to be saving me time.
So after messing with this shelf some more last night(for longer then I would like to admit) I got the flat pattern to work but I am having issues with unfold.
The flat pattern works with the flanges in direct contact but I cant get it to unfold as you did in your bracket video,
I wanted to do some bend relief cuts like you did in the bracket video because I am going to have to do the bends by hand or with an improvised “bending brake”, I made out of some scrap I had lying around that I clamp to my welding table.
The only way I can get it to unfold is if I have a gap the thickness of the material between my tabs and the adjacent flange.
So I guess my question is… is this gap it is showing normal and required or am I fouling the unfold feature with some mistake I have made along the way. I have tried all sorts of different ways to make this work folded it multiple different directions used every different type of flange tool and rule that I could think of.
I wish he would put on a class at his house called… How to work a full time job, be married, take care of your home, teach fusion, teach everything else you can think of, learn 3d scanning, make videos, edit videos, eat 3 meals a day, answer 60% or more of the questions asked on the forum, help people behind the scenes, learn how to live stream, sleep, bathe, (I could keep going)
Just think about all the stuff he does, as I say he is a freaking machine!!! (not sure that really describes him)
I’m going to live stream in about 10-15 minutes. (4:45am pst)
I’m going to come up with a different version of the large beam hanger made out of quarter inch plate that was working on the other day.
Also I noticed my videos from a week ago are disappearing off twitch now.
I’m going to try to upload all those videos to YouTube and replace the twitch links so people still have access to the videos.
But I will still do live streams on twitch I’ll just make sure I also upload it to YouTube in the future.
