Im about to upgrade my compressor and filtration system. Tsunami triple filtration system. I am not certain which I should get. I have a hypertherm 45xp and user manual mentions the hose diameter should be 3/8“. Tsunami comes in either a 20 CFM with 1/4” NPT or 50 CFM with 1/2” NPT. Any input or recommendations? I am getting an 80 gallon compressor rated at 16cfm at 90 psi single stage.
Be careful with min hose size. I have a Hypertherm 45xp and the unit requires u to use a certain size hose and connectors or larger. Here is what was cited in the manufacture manual “ Do not use hoses with an internal diameter less than 9.5 mm (3/8 inch). Hoses that are too small can cause issues with cut quality and cut performance.”
Reason I mention this is tsunami makes some filters that matched my PSI and CFM requirements but they took too small of a hose.
Hmmm that’s interesting… I’m running the Razor Weld 45. I’ll look around to see if the min hose size is relevant to the RZ45. I went with the 20 cfm setup…
