Trying to get easy scriber to work with crossfire Pro
Thank I need to turn Ihs off in postprocessor not really sure how to do this can somebody help me thank you
Which post processor? Fusion or Sheetcam?
Looking at the Sheetcam postprocessor, IHS is turned off IF pierce height and cut height are both set to 0.
I am using sheet cam
I need to get scribe lower to dig in
Almost like a negative z command
im having the same issue with 1.6 post
The problem might be the floating Z. You can’t introduce more force into Z (unless you really jam it, of course!).
