Trying to find cut charts for stahlwerk cut 50 pilot
Hello to all,
I’m trying to find toolset for sheetcam or at least a cut chart for stahlwerk Cut 50P. I had a powermax 45 but I want to have a replacement plasma in case mine defects so I’ve bought a CUT50p from stahlwerk but can’t find any cut chart or toolset. If someone have it would be appreciated !
Thanks
Is this plasma a high frequency? High frequency plasma cutters shouldn’t be used with a langmuir table.
This the plasma you bought?
@Phillipw is correct. It will not work on the Langmuir table. I’m sorry; I know that’s not what you wanted to hear. $ 350 US . There are several options on Amazon for the same money.
It must be non high frequency start. Read descriptions very carefully.
The description MUST include BlowBack start. That is key.
yes it’s the model i’ve bought but we’ve bought isolated gain for protect cables
I don’t think it is worth the risk. You will probably fry the tables control box.
As pointed out by others, you definitely don’t want to use that cutter on your table. See compatibility requirements below.
https://www.langmuirsystems.com/plasma-cutters
I’m curious of which cables you did this to? And which isolating device you used.
This is a good article about plasma cutting and high frequency.
Plasma Cutters for Hobbyist CNC Tables
