I think I have done it before but can’t seem to find it again.
In the free version, as long as you are below 10 editable documents, it should be an available option in the drop down immediately below the file name. If you are at 10, you’ll have to change another to Read Only before you can make the change.
Like Bret said you must be under 10 editable before you can add another. you might need to change a few other ones to Read only.
Thanks guys, what I was missing was clicking the little house icon to get to my project lists.
Lack of basic computerization skills I guess. Thanks again…
I don’t know how to get my page to get it back to editable. My computer is not showing the way shown.
First question: Windows or Mac
If Windows, I’ll be happy to help. If Mac, you’ll need someone with personal experience.
When you start Fusion (usually), the left portion of the screen is the Data Panel. Unless you’ve added additional Project folders, you’ll want the Admin folder. (This is the default Fusion workspace.) Double click and it should open showing your projects. From that point, each project has a drop down for Read Only or Editable. If you already have 10 Editable projects, you’ll need to switch a few to create new projects.
