Got the table up and cutting my first project this weekend. Had the breaker in the panel trip twice do to splash up of water onto the torch. Is there a setting to move the torch from cut to cut quicker rather then have it sit in one spot before it moves?
Splashing water shouldn’t cause a breaker to trip.
But your question about how long it sits between cuts is based on the cutter’s specifics for what it sets its “postflow” to. It’s cooling the tip when it sits waiting.
W water splash shouldn’t be the cause of the circuit breaker tripping be sure you’re on a properly rated breaker mine is on a 50 amp 220 as for the pause time between cuts it is configurable in Mach III Configuration settings I believe the default was one second I changed mine to three seconds which gives me time to either pause or remove any tip ups
