Ok so I tried to make a change in this sketch which I think I was able to do do, but the tool path still shows the line I cut out. The history is turned off because that’s the only way I could get the option to edit the file. So maybe I did not trim the line that I thought I did?
Sometimes it has problems updating the view ,click a few spots, open a couple menus and the view may update and the toolpath is likely already updated.
Ok well So I deleted the extrude and thought I got it. Its different but still not right.
Here is the file from my original post. This is before my last go around with extrude
Should I have uploaded the file before I made any changes? (seems like this would be better because I think my changes made you fix it different then if you would have got the original file)
So I went back to original and was going to see if I could do a better job of making the change.
I already hit a snag and don’t know why.
I have the original file open and the one I sent to you.
Because you have history turned off. Try to select a piece of sketch geometry and then right click on it and I believe that edit sketch will be in the menu.
Seems like you’re looking at both the sketch in the body maybe at a skewed view
If you look in manufacturing it’s likely included in the toolpath.
But I would suggest turning on your history by right clicking the very top item on your browser bar right hand side of the screen when you first start a file. Select the option from the menu
