is there anyway kind of travel compensation that I am missing in Cut? I seem to be off on hole positioning and parts are not exact size. So I zero work piece and start the cut. 1st operation is cutting 1 hole then cutting out the piece. The hole is .200 off from what it should be. Print is correct and it appears that the diagram in cut control looks right (would see .200 off). What am I missing ?
Any chance you have your kerf width wrong? Kinda sounds like it if everything is off the same amount.
