just throwing this out here, i am getting a new laptop with a ryzen 7 processor because my hp laptop is too under powered to run fusion360. i am wondering if anyone has been able to transfer fusion 360 over to another laptop from a previous one or do i have to download fusion all over again, also will all of my stuff saved on fusion be able to be moved to the new laptop?
i dont want to lose anything by switching to a new laptop like past projects, a subsription to fusion and all my posts to fire control. i am guessing i will have to download firecontrol on the new laptop, i just want to avoid jumping back and forth between laptops. thanks in advance for any advice.
Fusion is linked to your Autodesk Account. All you have to do is download Fusion to the new laptop and sign-in to your Autodesk account. All your files saved in Fusion are cloud based and will appear as normal.
Files you have exported from Fusion to your old laptop and G-Code files will have to be copied over to the new laptop.
To avoid an error sign out of Fusion in the original laptop first. But you can install Fusion on as many machines as you like the limit is you can only be signed into and running Fusion on one at a time. I have it installed on 3 or 4 machines.
awesome thanks guys.
