I’m using a everlast powerplasma 50 wired to the cnc port on a crossfire pro. I checked the torch firing cable with a multi-meter when the trigger of the torch is not depressed it has conductivity and when I press the trigger it has no conductivity. this is opposite of what it shows in the set up videos. When I manually fire the torch in fire control the torch turns on but when I hit the torch off it wont turn off until i hit the on/off switch on the plasma cutter.
Have you checked…
Page 16, note 6
yep turned it to t2 and it solved the problem thank you.
