I have Crossfire Pro XR, and I refuse to pay for Fusion 360, So I use CutArc, it runs the machine, WAAAAAAYYYY easier than FireControl, as you can design and run the machine in the same window. Problem is the torch keeps saying torch off M5. Not sure how to get the torch to turn on. I can build Houses(licensed contractor), and Semiconductors(whole different topic for elsewhere), I don’t understand Firecontrol well enough to use it. Also not quite sure why Firecontrol was’nt setup and ready when the machine arrived, and not sure why there wasn’t some sort of free cad software included for designing when you spend over $6k on a machine. This should’ve been assemble and run, and its been a month since it was assembled and still haven’t cut a damn thing. Anyway help would be greatly appreciated.
welcome to the forum.
there is a free hobbyist version of There is a free hobbyist version of fusion 360 available Autodesk Fusion available.
https://www.autodesk.com/ca-en/products/fusion-360/personal
it sounds CutArc it’s not running your machine based on the topic of your post. There’s a high potential likelihood that it’s not producing G code correctly to run the machine.
Try developing a simple program for a circle or a square and posting the G code here.
I would suggest going to the software page and downloading and installing fire control. Once you’ve done that try to run some straight line cuts from within the fire control program to see if everything’s communicating with your plasma torch.
M5 is torch off.
M3 is torch on.
Cut Arc says they have a Firecontrol compatible post processor, are you selecting that to generate your code?
Even when I use fire control, it will not activate the torch for some reason.
Post the first 15 lines of code here. Those of us that understand it will be able to see the issue.
Edit: I did a test design and generated code using the Cut arc website and the code has a lot of issues that will prevent it from running in Firecontrol.
This is the code generated by Cut Arc":
G20 ; Units: inches
G90 ; Absolute positioning
G17 ; XY plane selection
G0 Z0.984 ; Safe height
; Cut order: inside-out
; === Shape 1: circle ===
G0 X8.166 Y6.268
G0 Z0.984 ; Safe height before probe
G38.2 Z-5 F100
G38.2 Z-5 F25
G92 Z0 ; Set Z reference
G1 X8.166 Y6.268 F62.992 ; Linear move after probe
G0 Z0.15 ; Pierce height
M3 H1 ; Torch ON
G4 P0.4 ; Pierce delay
G1 Z0.059 F31.496 ; Cut height
H1 ; THC lockout (pierce zone)
G3 X4.016 Y6.268 I-2.075 J0 F62.992
H0 ; THC lockout end
H1 ; THC lockout (end zone)
G3 X8.166 Y6.268 I2.075 J0 F62.992
M5 ; Torch OFF
H0 ; THC OFF
This is from a Sheetcam cut file that I generated for a different design:
(v1.6-sc) - This line is important and is missing from the Cut Arc file
G90 G94
G17
G20 (Units: Inches)
H0
G0 X1.0 Y1.125
G92 Z0.
G38.2 Z-5.0 F100.0
G38.4 Z0.5 F20.0 - This line is wrong in the Cut Arc file
G92 Z0.0
G0 Z0.02 (IHS Backlash)
G92 Z0.0
G0 Z0.13 (Pierce Height)
M3
G4 P0.6
G1 Z0.04 F70.0 (Cut Height)
H1
G1 F65.0
G3 X0.9311 Y1.1939 I-0.0345 J0.0345 F39.0
G3 X0.9025 Y1.125 I0.0689 J-0.0689 F32.5
G3 X1.0 Y1.0275 I0.0975 J0.0
G3 X1.0975 Y1.125 I0.0 J0.0975
G3 X1.0 Y1.2225 I-0.0975 J0.0
G3 X0.9311 Y1.1939 I0.0 J-0.0975
G3 X0.9452 Y1.1229 I0.0426 J-0.0284
H0
M5
G4 P0.5
G0 Z1.0
The Cut Arc file is missing the ID line at the beginning that identifies it to Firecontrol as an approved file type. The only two that I know of are (V1.6-sc) Sheetcam and (V1.6-af) Fusion.
The second line of the IHS probe function is G38.2, when it should be a G38.4.
The last line of the Cut Arc file is missing the program speed, which should look like (PS??) ??= cut speed. This line is not shown in either example above, because they are not complete files, but it is missing in the Cut Arc file.
The THC activation codes are the correct codes, but used more often than necessary. This is probably not causing any issues, though.
; CutArc G-Code Generator
; Generated: 2026-08-02
; Shapes: 70
; Post-processor: Langmuir FireControl
; Design Units: in
; Output Units: in
; Corner Slowdown: 55% at angles < 105 deg
; THC Lockout: pierce 0.3in, end 0.3in, corners +/-0.1/0.1in
; Toolpath bounds: X[0.14, 48.00] Y[17.92, 47.84] in
; Material: 48.00 x 48.00 in
; Header
N10 G20 ; Units: inches
N20 G90 ; Absolute positioning
N30 G17 ; XY plane selection
N40 G0 Z0.984 ; Safe height
; Small feature (0.3in) - reduced feed to 50%
; === Shape 1: custom ===
G0 X4.294 Y19.571
G38.2 Z-5 F100
G38.4 Z0.5 F20 ; retract probe (sanitizer fix - was duplicate G38.2)
G1 X4.294 Y19.571 F47.244 ; Linear move after probe
G0 Z0.197 ; Pierce height
M3 H1 ; Torch ON
G1 X4.371 Y19.387 Z0.079 F0.335 ; Rolling pierce
I am either gonna get this figured out or the control Box is gonna sell, and I will build my own. I already have the software built. and the parts sourced. so if it doesn’t work, I will see if I can post the control box for sale on here. its a Brand New Pro Max, not XR. I wrote that wrong.
