Torch will stay active during transition from inside to outside cut
Razor Weld 45
If I’m making a bracket that has a hole in the center I usually command an inside cut first then outside cut. Often after it cuts the inside the torch will stay active during the transition to the outside and of course leave a line. When I watch it simulate it with Fusion 360 it doesn’t show this. Am I missing something?
Thanks
Is your plasma cutter set to ‘2T’?
I will check tomorrow at the shop.
My schedule with my primary business has been crazy. I finally got time to check yesterday and that was indeed the issue. Thanks for your help!
