Hi
Coming from a Mach 3 Crossfire to a Pro fire control
When i load my project file it is posistioned too far north (when i zoom out i can see it) of the torch posistion. The virtual table is bigger than my real (pro) table.
I can manually jog to the bottom of the project but there is no room left to cut.
What button moves the project to the the torch vs me trying to move the torch to the project.
You must pick the program origin and set your “work zero”. That will tell firecontrol where on table to start the program. The origin allows you to pick what of 5 positions to start as works zero you have the four corners and the center. Click the origin button then the desired green box for work zero to start at.
Thank you! Will try it Tommorrow
Lots of good information
Thanks guys! when i went back and tried it the next day the torch posistion cross hair reset perfectly, first try. Day before one axis would not reset ![]()
