RX7 AIR PUMP tin forum .nc (1.6 KB)
Air Pump Bracket 2 v10 tin forum v1.f3d (97.4 KB)
seems okay but a lot of lines of gcode to get the job done. Almost 600 lines . With fusions CAM try again and reduced it to 80 lines.
your 1000mm per minute program speed or 40 inches be minute maybe to fast or slow for the material, what material are you using?
Is the program trying to run at 1000 inch per minute?
here is a live stream looking it over.
