strand
October 29, 2024, 12:26pm
1
the torch will fire at the start of the cut and then shut off and finish that cut then rapid to the next spot and fire again and shut back off but it says the torch is lit and there are no alarms or error codes
Are you using a plasma machine with a 4T/2T switch? Is it switched to 4T? You want it on 2T.
If your plasma torch is either not firing when it should or if the torch is remaining on when it shouldn’t, your 2T/4T setting might be incorrect. In this post I will explain the difference between 2T/4T mode, and show you how to tell if your plasma cutter is set appropriately.
What is 2T/4T?
In 2-Touch mode, the first touch of the trigger engages the torch at the set amperage, then the second touch disengages the torch. 2T mode is the required setting for most CNC machines, including the Cro…
