can some one explain what the torch speed cut off parameter does it is set at 85% just curious of what it does and effect if you increase or decrease setting
thanks in advance
thanks in advance
That is the setting that tells Firecontrol when to turn the THC off. Any time the torch speed drops below 85% of the program speed, Firecontrol turns off the THC to prevent the torch from diving into the metal.
It’s best to leave it there unless you are trying to do something unusual, such as cutting corrugated metal.
