Hello everyone, Just getting started with my Crossfire Pro. I seemed to be doing fine with firecontrol v1.5. When I downloaded a project it would ask me to if it wanted me to convert file to v1.6. I would say yes and everything worked fine. I finally got around to updating to firecontrol v1.6 and now the torch only fires once. If I download file in 1.5 it works fine. Anyone else having this issue?
Yes, you are correct. Sorry for confusion. Still new to me. Post processor 1.5 torch fires multiple times. PP 1.6 only fires once and program pauses after second home fire attempt.
Attach the both versions of the gcode, the one that works and the one that doesn’t. Also provide the versions of the software you are using to generate the gcode (Sheetcam or Fusion?)
Tim, if you add a “.DXF” to the regular filename, the forum will allow you to upload it then…
The recipient of the file will just have to the remove the added on “.DXF”
