I finished assembling my CrossFire XL, did the alignment and break-in program. I wired up my THC using the raw voltage on the DINSE connectors inside my Everlast PowerPlasma 62i CNC package and soldered the Torch Firing wires onto Pins 1 and 2 of the CNC port. Next, I fired up the plasma cutter with good air supply and work clamp attached and tried to test the THC in FireControl v20.6.
I got past the first part of the Resting voltage test and got 1.0 - 1.2v. The problem started during the next portion of the test when it tried to dry-fire the torch. The air kicks on and is coming out of the torch, but no arc comes on.
Then I closed out of the test and tried to manually fire the torch in FireControl, and the same thing happened - air comes out, but no arc starts up.
This is a brand new plasma cutter and I did not get the hand torch, so I cannot verify that the plasma cutter works that way.
I turned the plasma cutter off and hit the manual torch fire button in FireControl and heard the relay click.
Any ideas?
@toolboy I think you have the same plasma cutter, so I hope you could jump in.
