Everytime I want to fire up my torch, I can’t even get a Voltage reading and the plasma cutter never even initiates an arc. I keep getting the message " TORCH STARTED MOVING BEFORE CUTTING VOLTAGE WAS SENSED." I have tried increasing my pierce delay, which it recommends as a solution. I have changed my pierce delay from the initial .5 seconds to .8, 2, and 5 seconds (which I feel like is a lot), but none of them have worked and the torch doesn’t even fire for my first cut.
Does the torch fire manually in fire control?
5 hours ago you posted you did not even have the THC wired up…did you get that fixed?
you also posted you are having problems with fusion360 posting the file from 360…
