Torch is firing between some cuts
I just did my first burn. everything is good except I got 3 spots during a move that the torch kept firing. I checked the g-code and it is telling the torch to turn off and on correctly with the M3 and M5 commands.
What could be causing this? using the razordweld x45 cutter
Lookup 2T vs 4T. You should be set for 2T.
Is that in the software or a dip switch in electronics?
Front panel of your Razorweld. Top row… but if you can’t find it, a tour of your User’s Manual might help. :expressionless:
As mentioned, 4T
Just like lots of welders
