I just bought my table with the razor weld 30i and wired up the torch wire to the trigger wires. When I plug it in to the control the torch fires no matter what even if the control box is turned off. What cloud my issue be?
Is it set for 4T?
You want 2T. That starts & stops with a trigger pull vs start and hold which on the Crossfire will result in a steady on. It needs the plasma set to 2T.
