have the Crossfire with XL kit, THC and running Razorweld cut 45. System is brand new.
Problems:
- Torch fire stays on at end of any cut and won’t stop. Hitting stop within firecontrol will not turn it off. I must physically power off the plasma cutter.
- Torch stops during programs either right at the start of cutting and just keeps firing through the metal and can not be shut down without powering down the plasma cutter.
- I tried to update firmware for THC but the link you give does not work. It is a dead link.
- When attempting to run a cut program I always get the Error: TORCH STARTED MOVING BEFORE CUTTING VOLTAGE WAS SENSED
