So when I go to do the cutting simulation in cam, I notice the torch is on the opposite z axis then it should be. So I assumed that it must be the model orientation, but when I click select x and y axis, it still oriantates the torch on the wrong side, which in turn makes the tool path run in the opposite direction that it needs to be. Any tips?
Hey Andy, sounds like you had the Z axis oriented the wrong direction. Go back into setup, and click ‘flip direction’ for the Z axis.
Thanks Daniel, I was actually able to click the z axis arrow and it flipped it to the correct side
