Currently I am using a Titanium 45a Plasma Cutter and as I am working in Sheetcam would like to become more specific with my tool settings, such as pierce delay and feed rate. I notice other plasma cutters have torch setups in their manuals, offering specifics like this. I am having a hard time finding this information for my Titanium. Would anyone have some resource recommendations?
Here is some of my settings guys. YOU might have to tweak a little do to air supply. what torch and what internal air pressure is set on your titanium machine. I set my internal machine air pressure to 75 psi. cuts great after hours of adjusting cut speeds, pierce delays and air pressure.
make sure you have dry air supply to cutter and good water trap and filter( look at my setup) works great.
16 gauge steel. 195 imp. .9 second delay at .05 cut height. plunge rate 60 imp.
11 gauge steel .155 imp .9 .05 60
3/16" steel 75 imp 1.second .05 60
1/4" steel 53 ipm 1.3 .05 60
1/2" steel 24 ipm 1.3 .05 60
The air supply to outside of cutter is 110 psi. When you take cover off plasma machine you will see the internal air pressure regulator. Turn the top of regulator adjustment clockwise 1 to 1 1/2 turns to increase torch air pressure.
