Titan Variants. thoughts or speculation 🧠
Any thoughts or speculation of future Titan variants out there?
examples ideas
5 foot 50 ton
6 foot 75 ton
CNC leaf brake
CNC horizontal bending and straightening machine
CNC shop press
all of these could use the existing UI with some modifications.
what kind of ideas do you have?
what would you like to see?
Shop press 30 ton
Leaf brake
Maybe a second Titan.
I thought that they (Langmuir) would have spit out a smallish CNC lathe by now to complement the MR1
Stierli Bieger 420 CNC W Hybrid Stierli Bieger 420 CNC W Hybrid
I almost bought a manual version of one of these years ago. It does seem very functional for many many bending tasks.
It would be cool if Langmuir made a Titan version
One ram and one axis on the back gauge. Basic half a titan
I had brought up the idea once that the Titan could have been designed in a way that you could stack multiple Titan 25T’s together to make a longer bigger machine.
For example you can take three Titans 25’s and arrange them side by side bolting together. then have thier software sync with each other so it becomes one machine
Then you could add to your shops bending capacity one purchase at a time.
Width, but I think you would lose bending force exponentially The Wider it got with the structure that they have
I would be up for that purchase as the lathe is one of my most often used machines in my shop!
I wish it were 8 inches taller. I have plans to mill some risers, but I never get around to it
After 5 minutes, I must pull up a stool to sit down to bend stuff.
The new quick release handles that was suggested here are a big improvement.
A forth axis for the MR1 is my wish. Hopefully I will live to see one offered.
I found this that I posted when we are all still waiting for the Titan to be shipped
ezgif-2-36bd6e6f30
ezgif-4-a8e6bd71a6
Are you bored, Tin Man? Someone worked hard on that collage.
So cursed, haha.
O heck yeah! That and a BT30 spindle with a tool library in cut control! Now that I’m starting to push it harder tool pull-out is the limiting factor. I’ll just have to go with bigger stepover and less DOC.
