I have my back gauge all installed and when I finally got the machine to boot up it will not let me jog the back gauge it shows them moving on the screen, but nothing happens, it will also not let me home the machine, it loads the homing icon endlessly then when you cancel it, it says hydraulic shutdown! I’ve unplugged and plugged back in reset everything, checked everything I did find two broken wires and fixed them but that did not make a difference…not really sure where to go next.
I had the same exact issue, and yes the back guage field was illuminated green on the screen. My issue was the power supply for the back gauge, it was dead on arrival. You might want to check the selection switch on the side of the power supply itself, to make sure it’s set to 220V and not 120V. A simple volt meter on the power supply red/black will tell you if it’s working or not.
Again… Is it green?
Too use the back gauge functions you need to be on the back gauge page. The page displayed is the press page. Touch the back gauge tab at the top of the page then try home.
