For CAD Wednesday, I played around in F360 to make a bracket for my intake. Currently the only one that is available is one that bolts behind the TB (it’s a plate, has two gaskets one on each side).
My design mounts to the fuel rails bracket, the cable is a MR Gasket cable and I used the plastic hardware that came with it.
Nicely done! Looks better than most throttle brackets that come with the more inexpensive intakes.
I have the FiTech intake on my LS in my c10 build and will eventually need a throttle bracket solution.
That’s pretty awesome, you should jump onto some forums and post them for sale. Seems like easy money, great design and there’s a product vacuum in that application. Nice work!
May be a dumb question but how did you get those bends in different directions. I’m trying to think of how I’d do it in my brake… maybe my perspective is off
I have a harbor freight modified bench bender that can handle 14ga or so. I do the big bend in it and then the brkt goes into a vice, and i use a bending plier and “deez guns” (pointing at biceps lol) to do the throttle cable end bend
