Looking at upgrading from the Pro and curious if the same hookups for the plasma cutter are used. ie: just unplug torch from one table control box to the other?
Yes, plugs are same. The XR comes with THC module you will have to connect it to your plasma cutter if you don’t currently have THC. Reference to the assembly guide for XR and go to THC guide and will show how to connect.
Thanks I have the THC so sounds like an easy swap.
