When I purchased my crossfire I already had a plasma cutter…the Thermal Dynamics Pak Master 75 and I figured it would work on the crossfire system. I have received my crossfire but haven’t had a chance to put it together yet, and after reading some info I am not sure if the Pak Master 75 will work with the crossfire or not, because of it being an older machine. Can anyone please let me know if it is compatible or not with the Crossfire system. Thank you!
I have the same plasma cutter as roscoe(pac Master 75) and would like to know if it is compatible as well. Thanks.
Snuffy I contacted Thermal Dynamics and they said the Pak Master 75 is a high frequency machine
Roscoe185, Thank you Sir! Guess I’ll be looking at newer Plasma machines as well.
