THC Z zero question
Running an XR I just switched to a SYNC45 from a razr45 and seeing the same thing. Sometime my cuts stop and say no voltage detected. Notice when I restart that the Z zero point is not the same and have to reset it to continue the cut. when the cuts done the Z height is not even close to where it was in the beginning, Just wondering why the Zero point from the beginning is not the same after the cuts or completely changes. Or is this supposed to be this way? Any help would be appreciated!
I’m slightly confused by what you’re asking, but maybe explaining how things work can help to pinpoint your issue.
Do you know how IHS works? This is when your torch physically jogs down, touches off your material which opens up the contact points in your Z axis to trigger “hey, we found your material”. This is basically your zero point, which includes a springback adjustment to make up the additional movement from touching your material and triggering IHS.
At this point Firecontrol knows where your torch is physically. Knowing this, it jogs up to your programmed Pierce Height and pierces your material. It continues piercing while measuring voltage, and jogs down to your programmed cut height.
While all this is happening, Firecontrol now has a “reference” voltage that it will maintain as your torch runs along its cut path and cuts your material.
If you have crud or any junk on your Z axis assembly, a bent tab (I’ve seen this before for others), or incorrect programmed heights, it could lead to weird issues. EMI can also lead to such things, as well as moisture in one’s air and more.
There are tons of variables that can affect plasma cutting but the above should help to figure out your issue.
Share your settings, ALL of them, along with how you’re wired up and how your torch is mounted.
Ok maybe this can help, it works to begin with no problem on small parts and It stays within the pierce and cut settings.
When I cut a full sheet of 1/8” with multiple cuts and pieces it is like it gets confused of the torch height about half way through the sheet. Then does the voltage not found error.
I then reset the Z back at zero on the material and it will finish the rest of the sheet. I have the settings in sheetcam set to the recommend sync45 settings from the chart.
I have tried changing the cut and pierce settings and it still does the same thing.
When the cuts are complete shouldn’t the z zero be still at the same zero point setting I started with? Just wondered why the Z zero point is off when its complete. Does the THC change the zero point every time it cuts no matter where I set the zero on Z?
This is also happening when I use the THC On 1/4” sheets that are relatively flat.
I can turn off the THC on the 1/4 and it remains the same zero when complete.
Is it possible the THC controller is bad or maybe a THC setting I need to change?
Sorry if this is confusing. I do appreciate your help and explanations.
So, you need to share your settings which you still haven’t.
Both what you’re running when it works, and what you changed when you tried fixing it since you said you changed things.
When you say it has issues half way through the sheet, can you specify whether - this issue occurs IN THE MIDDLE OF AN ACTIVE CUT, or simply half way through the program on a new cut path for the same program?
Specific details help because if it’s during the cut, I can advise you to watch Firecontrol and see if IHS is being triggered. IHS being triggered DURING cutting will reset Z and cause the torch to physically jog up since it’s initial reference is reset.
But if it happens on a NEW cut path, are you paying attention to the physical movement of the torch? This is because maybe there’s crud on your retaining cap, or your IHS is dirty, or the tab is damaged and it’s triggering a false touch off. Could even be an issue with an incorrectly mounted torch where you’re riding at the bottom of your travel.
Again, trying to help but there’s a reason to the specific questions being asked and a reason to the specific pictures requested.
The IHS system sets the Z zero at the plate surface on every cut loop.
Where you zero the Z axis before starting a cut means nothing other than that is the Z height when you press start. It will never go back to that Z zero again. You can zero it at 3 inches above the plate, if you want.
If you are getting the “no voltage detected” error, it’s probably because the pierce delay is too short. The Hypertherm chart delays are too short for the Langmuir control system. It will usually work fine on the first pierce, because Firecontrol makes the first pierce delay longer for some reason.
Good point if the issue is a “zero voltage detected”.
The use of different verbiage and no specific answers makes it hard to pinpoint things!
Still, the author answering the above question about “what settings” are used exactly will help a ton.
Especially since it was mentioned that they’re using “Sheetcam settings” when really most charts are user-provided and sometimes people mistakenly use the XP charts for their Sync. This will automatically provide the wrong cut and pierce heights since the two are different.
