Reviewing gcode I don’t see any reason for the z axis to lift on the parameter of the arm but could post the code here if anyone has any ideas.
I got the table to pause (had to use M00, M0 did not work) and return to X0Y0 and it worked perfect in a dry run but when I ran it while cutting I got the “Arc Voltage Lost” error and I could not get it to “run from here” or start the next cut cycle for anything. The first time I tried it I had an additional Z lift to the 1" retract that is defaulted in the LS post processer, so I removed that and tried again. Still get the same issue. Any ideas how to make this work?
Interesting. I was using 20.4 Firecontrol yesterday and got the pauses to work fine with M0. I did get the Arc Voltage Lost error each time - it was a little non-intuitive - it took me a few times to figure out that I needed to click ‘continue’ not ‘run from here’. When I did that, the dialog would disappear, table stayed in pause, and I just un-paused it and kept going until the next arc lost. The arc lost was a little annoying - a few extra clicks, but it worked.
I can try M0 with v 20.4 and see if it works. I was on an older version when I first tried with M0, so I have been using M00 since. Thanks for the feedback
