I’m having a lot of issues with my new table
- The torch is not being recognized through the software
- When I did get the torch to run it shut down the fire software and had the laptop real distorted
- I ran the break-in program again and now the x- Axis motor has gone out
I need some help
@Hfcustomwelding welcome to The Forum.
Which plasma torch do you have?
Which table do you have?
Do you have a THC ( torch height control)?
If so how is it hooked up?
Check to make sure the x axis motor couplers are tight and the motor connectors are seated well.
I have a cuwiney # CUT50D
I checked the coupling it was tight then I removed the motor from the mount and it has gone out. It comes on but the shaft doesn’t move
Also no height control it’s manual
So that unitis likely a high frequency start unit by the looks of the torch.
High frequency start units are not compatible with the electronics on the langmuir controls.
Watch the first 4 minutes of this video but 2 minutes and 40 seconds has the best explanation.
Check out this plasma compatibility chart from the langmuir main site.
https://www.langmuirsystems.com/plasma-cutters#plasma-cutters-table
