Anyone have a simple guide on wiring the Lotos Supreme Cut60D to the Plasma Table?
Hi Blake,
We have generic instructions in our user guide for wiring your plasma cutter. Check it out here: http://www.langmuirsystems.com/user-guide You’ll need to scroll down to the section titled “Plasma Cutter Wiring”.
blake,
I’m still waiting on the table but from reading the manual for the Supreme Cut60D and the Crossfire hook up should be simple. You need to hook pins 1 and 2 on the 12 Pin CNC plug on the Supreme Cut60D to the Torch On/Off Jack on the CrossFire electronics box. Most of the other pins in the CNC Plug are only needed when using a THC (Torch height Controller).
I’m looking forward to testing this out once my Table shows up.
Good luck,
Bruce
