Anyone know why the crossfire xr would get stuck in jog state w blue indicator light but not be able to move at all? This happened after completing a cut. Ive tried restarting the program and the machine.
Blue light means movement with the arrows keys.
do you have a key stuck on the keyboard?
@Kstumpf welcome to the forum
Hey thanks for the reply, the issue actually resolved after a brief shut down of the machine but happens again once theres a long idle. Think it could be software or computer hardware ( memory) related?
so if you just turn on your machine and leave it after a time it’ll change the light from flashing green standby led to a solid blue LED and lock out all the controls?
Likely one of the two. Is the langmuir enclosure plugged into an outlet with a working ground?
If the Motion Control Board is sending the incorrect signal, we can put it to the test. I can send you out a new one and see how the machine behaves once installed.
