How many amps?
Is this the first time you have tried holes in 1/2" plate?
Maybe table is binding in the X or Y axis?
Have you cut holes successfully in the past?
Running at 65 amp 72 psi should I change any of these setting?
We have cut 1/2 plate before with moderated success first time cutting holes
X and Y axis seam ok
trying to figure out if I have the correct setting for 1/2" plate any help would be great
Rat
I will try setting Plunge rate to 60 ipm
Will try starting hole in center but do not think that is it. The flat spot is on the other side of the lead in but will give that a shot
BINGO! That is my guess. If you have not done it yet, use some lubrication on the lead screws. Many use silicone spray, others use fine machine oils or WD-40.
Make sure the couplers (where the motor shaft attached to the screw) are tight.
