Does anyone know how to program just a straight line cut? I use Inkscape and sheetcam. The only thing I have figured out is to cut out a really long rectangle. I know it’s probably a silly question.
You can do it in fire control btm left side of screen.
Draw a straight line in Inkscape. Save it as an SVG (regular SVG, not the Inkscape optimized type). Import that into Sheetcam. Create a cutting operation for the line - make sure it’s a no-offset cutting operation. Create the GCode and load that into FireControl to cut.
Thanks James. I’ll give that a try.
Thanks madman. I figured that out. I’m trying to program just straight cuts. Mainly for bend relief.
