I’m having an issue with my crossfire cutting round holes. It has flat spots. They are repeatable and the same every time. I have checked all the motor couplers and bearings. Everything that should be tight is and everything that should move easily does. For testing I created a simple 2” square with a 1” circle in CAD. The square is square and true to dimension. The circle is not. I used Sheetcam to generate the GCode and FireControl to the crossfire.
Lead screw bracket bolts loose?
Wow I feel like a dummy.
That’s for the help!!
That was it. The lead screw bracket was loose.
It happens. Happy cutting. Not a bad idea to check them a few times after assembly
Your giving tin a run for his
Money. Nice job
That would be a accomplishment for sure.
