I am looking for help with Adobe Illustrator to SheetCAM to CrossFire setup, thanks. can be for a fee!
This is my specialty. $50 an hour, but I don’t use Adobe, I use Affinity Designer.
Although if you’re competent in Adobe, just export as an svg at 96 dpi into sheet cam. Done.
I think @jamesdhatch can probably give you a thumbnail. He uses Illustrator (on some things) and is a maven on this forum!
I got my system to work, the cut are not clean and I need to adjust the speed, will keep you in mind, thanks again.
