Just finished setting up new Pro. Looking for suggestions on starting water level in pans. What have you found works best? (FYI going to use Razor cut 45) Thanks
I filled the pan of my Crossfire XL to within an inch of the top of the slats (about 5 1/2 gallons), it wasn’t enough. After I filter the cutting fluid and put back in the pan I will add at least another gallon and maybe two. I’m just learning too but feel that filling to 1/2" to the top of the slats will be best. Your mileage may vary!!
Thanks
