Stainless steel water table
Has anybody thought of, or made a stainless water table? I am fortunate enough to have access at work to endless amounts of stainless of all different gauges. Any thoughts or comments about a stainless water table would be greatly appreciated! I just figure it would cut down on any or all corrosion issues… and look good also! Thanks in advance!
I see no reason not to make one out of stainless steel except cost. But it sounds like you’ve got that covered
A stainless water tray won’t corrode. If you have free stainless, that sounds like a great project!
@langmuir-daniel Its not free, but I get it for cost, so it’s a pretty good deal!
jd2 makes theirs out of stainless. Do it!
Stainless water table in the works… 14ga was cheaper than 16ga :thinking:
Nice job. Keep us posted about how it holds up to standing water.
I’m going to put a drain in it eventually… plus a holding tank and a shelf. Between my kids, work, and life in general I haven’t had much time to play! :rofl:
Stainless is the route I want to go. Only thing holding me back is I wan to extend my Y axis and don’t want to remake a table! That press brake is insane.
Ahhh, I miss the days that I had access to a full blown shop… :cry: 250ton cnc brake press, 10x20 high def plasma… with a boss generous enough to let us use it all on personal gigs
After a couple weeks of burning, my stainless water table… it turned green. Other that, it is holding up great!
