Stainless lead screws for Crossfire - Solved: Source Recommendation Given
Guys, I live near the ocean. Lead screw corrosion is a never-ending fight. Can I get the lead screws in stainless?
Don
Lead screws are an off the shelf component. You should be able to order them from anywhere that supplies them in the correct thread/pitch/leads and material. Amazon possibly, or Automation Direct, or one of the other online machine components supply companies would be the places to start.
I suspect Langmuir isn’t going to be much help outside of telling you the correct specs to look for as they’re not a parts supplier outside of their OEM parts.
McMaster Carr has lead screws that will work. You need 3/8-8 4 start acme thread. A 3’ length in 304 stainless is $74. You’ll have to do some machining to adapt it to the table.
Thanks a million. Big help.
Don
Thanks for the tip.
Don
