Hey everyone I’m sorry for posting this as I’m sure it’s been asked a bunch already I just can’t find it. I have a boat load of 18ga ss to cut and I’m having a horrible time dialing in my razor weld 45 to cut it cleanly. This is my first time cutting SS on it and I’ve been playing with amps , volts speeds ect . If anyone could just point me in the right direction for a starting point I would greatly appreciate it !! I have not tried fine cut consumables yet either . Thanks for any advice you can give !!
What setting are you using?
Got pictures of cuts?
Ss doesn’t ge the bests cuts on compressed air.
These are the things I’ve been trying. Also this is 20ga not 18ga. I haven’t recieved the 18ga yet just trying to figure out settings for the best cut. These are just test pieces the pieces I’m actually cutting are much larger .
Picture is hard for me to tell a lot I ran a rw45 for almost a year. It was always about half of a hpertherm. My hypertherm book on 45 amp 22ga. Says 350 Imp try 175ish.
18 ga says the same.
Do you have the rw cut chart. I don’t think it has any SS on it.
Is your issue slag (dross)?
