How do I go about squaring off the end of a sheet of steel after I’ve cut my project out
Several ways but you can click on plasma on or press F5 plasma in Mach3 it will fire the torch and press the arrow in the direction you want to cut. Oh and don’t forget to hit F5 again to turn plasma off lol.
One more thing you will have to over ride your feed rate press the TAB key window will open on the right mid way down it says " slow jog rate" play with it until you achieve the feed you need. When done put jog rate back to 100% or when you run your next piece it will travel the speed between parts.
