Cut a few dozen pieces and turned machine off, the machine wont home and only the torch moves up and down, this has happened several times before but now nothing i do will make it move.
Ouch we have a machine due to ship to NC this week or next its all paid for… Hope you are getting support!! How is your grounding? We may drill through the slab and make a real earth ground. Ken
The control box inside has been replaced already (faulty) this one is doing the same thing, the small adjustable potentiometer inside continues to turn on its on counter clockwise thus not giving proper voltage i believe to the larger motors that need it, that must be why the Z was still moving but no others.
The software continues to be an issue, example the latest down load somehow disabled my limit switches and crashed the gantry into a hard stop.
And would love to know why they didn’t think a limit switch was necessary fro the z either i know that motor is smaller less powerful but come on!
I’m aware of this thank you. I like most have different plasma systems and came here to look at the new system Langmuir has to offer. With that being said, you do not need a limit switch on the z axis. If you’re so concerned about it, it’s extremely easy to put one on yourself. Otherwise get a magnetic breakaway and problem is solved.
On a side note, this system is far below what most systems charge. If you wanted all the bells and whistles, why didn’t you pay $25k for a decent system like I had too. Oh and you might ask why I would want this system if I already bought a $25k system… because I know how to modify and upgrade it to fit my needs.
Im sorry that you dont have an engineering mindset its actually quite simple.
The plastic torch cover should not come in contact with the torch on upwards travel in any way shape or form you have to be a complete idiot to think this is okay with automated machinery.
It literary pushes the cover off at times, a small built in adjustable hard stop is what it should have come with .
My god Im sorry but some of you need to stop inhaling noxious fumes because the small amount of brain cells you have left are dwindling away!
Lets take away all the other limit switch and hard stops and just be careful when you get close the the ends of travel when jogging the machine.
I see this went down hill from the original issue. I’m having the same problem. Immediately thought it’s a power supply problem, because the axis’s can be pushed around and they are not locked. Anybody got a picture of the Potentiometer location? And what voltage are we aiming for? I have one of the original batch of machines and haven’t really had any problems.
36V is the answer. Got ahold of Cameron. Adjusted the potentiometer up to 36 and it works fine. He recommended a new power supply, so I have one of those on the way also.
