@ChelanJim found it in post 27. 3D sketch needs to be turn on in the sketch pallet window.
Not sure what update did this one in.
New sketch
Draw rectangle. Used to be able to set the degree of the rectangle by tabbing over the degree box and enter in your degree, or IIRC clicking on the dot on the radius between X and Y if you needed it not parallel with X and Y.
Nope. Current on updates as of today. Closed and restarted F360. still can’t do it.
If you are drawing a rectangle you shouldn’t have to enter the angle as the default is 90 degrees. I think what you are describing would be a parallelogram.
Sorry… the engineer inside of me came right out of me this morning.
“R”
Left Click, drag into something, used to be an arc with the dot to click and rotate it to a degree - ergo a diamond, or tab over to degrees, select …45…then drag to your dimensions.
No, a parallelogram. Illustration # 4.
Bigdaddy2166 is still in Jersey. I have visited all my biker buddies, old girlfriends, and friends who still live here. Wake up for visitation tonight and go back to Tennessee tomorrow morning.
Back to the parallelogram. A Dog is a species. Right, but a St Bernard is totally different from a Chihuahua. A parallelogram is a Chihuahua in the quadrilateral, which is the species.
I really like that. Never heard that word before.
an instance of a form of reasoning in which a conclusion is drawn (whether validly or not) from two given or assumed propositions (premises), each of which shares a term with the conclusion, and shares a common or middle term not present in the conclusion (e.g., all dogs are animals; all animals have four legs; therefore all dogs have four legs ).
“All squares have four sides therefore all four sided objects are squares.” Clear as mud.
I think I missed a step, somewhere
Here I am hoping that someone knows what I am talking about, and either has not updated their F360 for a while and can do it, or now notices that that feature is gone.
I thought he was trying to change the angle of one of the corners. He said he would click on the dot and could tab to the angle measurement. But not now.
