Where is the work clamp? It must be on the metal your cutting. Also crank up the air pressure to around 78 psi on the front of the machine. It shouldn’t drop more than 3~5 psi while cutting.
Post your post processor settings. Cut height. 062, pierce height .12, delay .7
Bigdaddy2166
Aug 2024
cut height test.tap (224 Bytes)
Load the file onto FireControl. It will move the torch to the cut height and stop. You can measure the distance from the tip to the sheet. Report back with the findings.
