THC control panel doesnt light up, wont jog ,LS-THC light lights up but not sharp like the green [machine] light .Any ideas? Wont load files.
did you purchase the THC unit with the table? if not, then it won’t light up.
if you did, then did you install it correctly on the control board?
Yes iI bought everything with the table.It was working perfect and then started this.
Everything is hooked up right.
Im using raw voltage. It’s an Everlast 62i.
My first thought would be to begin checking power supply voltages.
problem fixed. Loaded a driver wrong.
